Sponsored by: Innova
Nav Speed control
Old Jun 10, 2007 | 10:52 AM
blkhd's Avatar
blkhd
Nav Speed control
03 harley Davidson F150, I need the color and location of the speed control wire for my new Pioneer Z2.+
Thanks, Bob W
Old Jun 10, 2007 | 04:50 PM
ReAX's Avatar
ReAX
I had to pull this from a 2002, but it should work, just double check it.
ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|yellow & lt. grn/pur|+ |ignition harness |
| STARTER|green |+ |ignition harness |
| IGNITION|red/lt. green |+ |ignition harness |
| SECOND IGNITION|gray/yellow |+ |ignition harness |
| ACCESSORY|red/black |+ |ignition harness |
| SECOND ACCESSORY|blue/lt. green |+ |ignition harness |
| POWER LOCK|*1 | |*1 |
| POWER UNLOCK|*1 | |*1 |
| LOCK MOTOR|pink/black | |VSM *2 |
| UNLOCK MOTOR|red/orange | |VSM *2 |
| DISARM DEFEAT|pink/orange | |VSM *2 |
| PARKING LIGHTS +|brown | |headlight switch |
| HEADLIGHTS|red/yellow |+ |headlight switch |
| DOOR TRIGGER|black/lt. blue |+ |either kick panel |
| DOME SUPERVISION|use door trigger | | |
| FCTRY ALARM ARM| | | |
|FCTRY ALRM DISARM| | | |
| TACHOMETER|*3 | |ignition coils |
| SPEED SENSE|gray/black | |instrument cluster or *4 |
| BRAKE WIRE|lt. green |+ |brake pedal switch |
| HORN TRIGGER|blue |- |steering column or VSM *2 |
| WIPERS|blue/orange |- |steering column |
| LF WINDOW UP/DN|wht/blk - tan/lt blu|A |driver window switch |
| RF WINDOW UP/DN|wht/yel - tan/lt blu|A |driver kick panel |
| LR WINDOW UP/DN|gry/org - yel/lt blu|A |driver kick panel |
| RR WINDOW UP/DN|yel/blk - red/blk |A |driver kick panel |
| RADIO 12V|lt. green/purple |+ |radio |
| RADIO GROUND|black/lt. green |- |radio |
| RADIO SWITCH|pink |+ |radio |
| RADIO ILLUMINATE|lt blue/red (dimmer)|+ |radio |
| LF SPEAKER|org/lt grn-lt blu/wh| |radio |
| RF SPEAKER|wht/lt grn - grn/org| |radio |
| LR SPEAKER|gry/lt blu - tan/yel| |radio |
| RR SPEAKER|org/red - brn/pnk | |radio |
Notes:
*1 Without keyless entry use pink/yellow for lock and pink/lt. green for unlock. They are 5 wire reverse polarity mastered from the driver switch and found in either kick panel. With keyless entry use white/red for lock and black/white for unlock. They are negative trigger and found at the VSM. On the vehicles with keyless entry the GEM shuts down after the doors have been locked for a certain time period, to "wake-up" the system *2 The VSM (Vehicle Security Module) is to the right of the accelerator pedal above the transmission hump below the radio. Not accessible from radio opening. *3 For tach go to any one of the ignition coils and use the wire that is NOT red/lt. green. On diesel vehicles the tach wire is green or white, in a 42 pin plug under the clamp on the engine side of the air intake duct. On diesel vehicles the wait to start light is activated by a databus wire from the ECM. To do wait to start use a pulse timer relay *4 Also found at the radio on vehicles that have the in-dash CD changer.
Old Jun 11, 2007 | 07:56 PM
STXFitz's Avatar
STXFitz
i have an 05 f 150 stx that did not come with a in dash cd changer i put a eclipse nav unit it it the speed sence for it was a grey black wire in the radio harness.
bobfl
Aftermarket Products
Sep 3, 2002 09:47 PM
elliott
All Things Towing
Mar 3, 2002 08:31 PM
beall st bob
1997 - 2003 F150
Feb 14, 2002 11:22 AM
Bob_1
Sep 4, 2001 12:50 PM
bobfl
Jan 3, 2001 09:57 PM
