Sponsored by: Real Truck
Lift Size
Old Jun 9, 2007 | 09:23 PM
dlanc001's Avatar
dlanc001
Lift Size
I have bought another f250 super duty and want to know if anyone can tell me how I can determine the size of lift that it has. Is there a base configuration or height for a 2001 sd that I can measure from? Any help is appreciated.
Old Jun 10, 2007 | 12:13 AM
Bear Hunter's Avatar
Bear Hunter
Passenger side, bottom of frame (by bumpstop) to top of front axle. Stock distance on a 4x4 PSD is around 7.5"
Old Jun 10, 2007 | 10:09 AM
dlanc001's Avatar
dlanc001
Thanks, i'll go measure it now. Its a skyjacker lift that I think is either 6" or 8" because the truck has 36's on it (Super Swampers). I don't think they'd fit anything less.
Old Jun 10, 2007 | 10:16 AM
dlanc001's Avatar
dlanc001
It measured between 15 and 15 1/2 inches so I'm gonna go with being an 8" lift. Is there any component on a skyjacker lift that would have that written just to be sure?
Old Jun 10, 2007 | 03:28 PM
DCSpecial's Avatar
DCSpecial
Not unless you can read the part numbers on the leaf springs still...
But yes, axle tube to the bottom of the frame rail measurement of 15-15.5" would be a SJ 8".
Old Jun 15, 2007 | 08:26 AM
dlanc001's Avatar
dlanc001
Can anyone tell me the stock distance for the rear axle as well. I need new shocks and am trying to determine the rear lift size also so I know which size to order.
Old Jun 16, 2007 | 08:15 PM
DCSpecial's Avatar
DCSpecial
As long as you order front and rear shocks for a 8" lift you'll get the proper ones.
Personally, I'd go with DR shocks.
