95 f-150 wiring problems
Old Jun 9, 2007 | 06:06 PM
85camaroman's Avatar
85camaroman
I dont post on here much but i just bought a 95 f-150 and i have a few small wiring problems. to make a long story short the previous owner put a new steering colomn in for some unknown reason and ever since he put the colmn in the speedo and odometer doesnt work. and also the overdrive light on the colomn shifter blinks when the vehicle is on and running. any ideas on what could be wrong with it?
Old Jun 9, 2007 | 07:22 PM
subford's Avatar
subford
Check to see if you have a bad fuse.
Old Jun 9, 2007 | 07:50 PM
NeXtras's Avatar
NeXtras
should be fuse number 8... 15amp
Old Jun 9, 2007 | 10:28 PM
CharlesNeff's Avatar
CharlesNeff
Pinched wire somewhere. A wire got caught up in a bind during mechanical re-assembly or a connector was pried apart and a (one or more) contacts within a connector got pushed back partially out of it's housing when it was put back together.
Old Jun 9, 2007 | 11:44 PM
wanitlifted's Avatar
wanitlifted
get the codes pulled on it, the tranny light blinking means it has a code
