Distribitor?!?!?
Old Jun 9, 2007 | 01:16 PM
78midnightmudder's Avatar
78midnightmudder
Exclamation Distribitor?!?!?
OK now thatim learning a lil bout electricty?! my stock dist can only push the 12,000 volts, but i have a msd blaster 2 and msd 6A that are producing upwards of 45,000 volts....WHO MAKES A AFTER MARKET DISTRIBITOR????
Old Jun 9, 2007 | 06:40 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
I'm running the same coil with a Duraspark II dizzy...
Old Jun 9, 2007 | 07:24 PM
nevrenufhp's Avatar
nevrenufhp
Mallory makes a dual point, and Davis Unified makes an electronic. That, or a Duraspark setup with the MSD boinstructions say how to do it).
Old Jun 10, 2007 | 10:55 AM
nevrenufhp's Avatar
nevrenufhp
If you run MSD, you also need to open up the plug gap to .044-.045" to use that extra voltage.
Old Jun 10, 2007 | 01:04 PM
ridgerider3's Avatar
ridgerider3
I was running A Mallory UNILITE 47 series unit Mallory part #4563101 for 2 or 2 1/2 years, and the Ignition Module went bad.
It cost $373.99 new, and the UNILITE® Ignition Module, part number 605, is around a $100.
The stock distributor being powered by a MSD 6A box and Blaster 2 coil is doing just fine in the spark department.
Just my 2 pennies
Old Jun 12, 2007 | 02:32 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://www.performancedistributors.com/forddistributors.htm
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
https://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Branden17
May 16, 2014 11:42 AM
ColtonMullis
Apr 30, 2014 08:47 PM
djmichael24951
Feb 23, 2014 06:26 PM
ymtrebel806
Dec 3, 2006 07:55 AM
79_ford_400_guy
Oct 20, 2003 04:21 PM
