cooling fan, push or pull ?
Old Jun 9, 2007 | 05:07 AM
Jason6969's Avatar
Jason6969
Does the cooling fan supposed to push or pull the air through the radiator.?
Old Jun 9, 2007 | 05:11 AM
ford390gashog's Avatar
ford390gashog
It is made to pull.
Old Jun 9, 2007 | 07:51 AM
carrfamilynj's Avatar
carrfamilynj
For electric fans, you can get pushers but they are not as efficient as a puller, plus they obstruct air flow when they're not on, resulting in quicker heat build-up.
Old Jun 9, 2007 | 12:03 PM
Club Wagon's Avatar
Club Wagon
It depends if the fan is ahead or or behind the radiator. Those behind a radiator help pull air through, those in front help push air back through a radiator. At speed fans are rarely even needed since air pressure is enough to fed air through a radiator from front to back.
