Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
A Question
Old Jun 8, 2007 | 09:59 PM
51dueller's Avatar
51dueller
A Question
I have a question. I picked up those engines in town.
Here's what I got:
75 Ford 390
80's Dodge 318
72-78 Dodge 400
They are a pretty much scrap metal. Is anything worth keeping? The 390 crank is .020 under mains and rods.
Old Jun 8, 2007 | 10:08 PM
Fomoko1's Avatar
Fomoko1
You already know my answer....
Hang on to the 390 if you can, the rest of these engines is up to you.
Any luck on the job market yet? Are you out at the farm or in Saskatoon?
Old Jun 8, 2007 | 10:11 PM
51dueller's Avatar
51dueller
The 390's been bored .030 over. 1-7 cylinders are okay but #8 is F****ed. One cylinder head is okay but that is about it.
I'm currently out at the farm and is still searching for a job. I just finished fixing the 91 F-250. I rebuilt the differential and replaced the rear gas tank.
Snowking's Avatar
Snowking
Does the 318 have a auomatic tranny?
Old Jun 8, 2007 | 10:12 PM
51dueller's Avatar
51dueller
Just engine blocks.
Old Jun 8, 2007 | 10:14 PM
Fomoko1's Avatar
Fomoko1
You should be fixing the 92 instead......
Old Jun 9, 2007 | 03:08 AM
Dustin1690's Avatar
Dustin1690
Done deal better get going still a good truck Fom to puts around in i would get an engine in it
Old Jun 9, 2007 | 08:19 AM
96sherm's Avatar
96sherm
lol...the absorbed ukranian in me says keep every little bit of Ford stuff you can... actually, the deep down newfie in me says that too about the ford stuff...
Old Jun 9, 2007 | 09:42 AM
51dueller's Avatar
51dueller
Well since nobody wants any of the 390 parts, it's going to the scrap yard. The Dodge 400 big block might be salvagable.
Old Jun 9, 2007 | 11:11 AM
preppypyro's Avatar
preppypyro
Sucks to hear the 390 wasnt in a little better shape.
How hard was it to rebuild the rear end?
Old Jun 9, 2007 | 12:17 PM
51dueller's Avatar
51dueller
Well it seems the 318 and 400 blocks are salvagable.
As for the rear axle it was hard enough. I wouldn't attempt it without a shop manual, knowledge of how rear axles are constructed and you need the proper tools.
For the Sterling 10.25 you need at least:
hydraulic bearing puller set (good luck using standard ones)
3/4 socket set
Metric socket set
Bearing race installers
1/2 torque wrench click type
1/2 torque wrench dial or beam type
torque mutliplyier
Yoke holding tool or pipe wrench
Hammers
Prybars
If you doing it while the truck is on the ground, the box has to come off.
Old Jun 9, 2007 | 01:03 PM
preppypyro's Avatar
preppypyro
It does sound like alot of work. I bet you saved quite abit of cash doing it yourself too though.
Old Jun 9, 2007 | 01:11 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Save the crank and rods, they're 390 ONLY. You might consider saving the vibration damper, any and all pulleys and the cylinder heads. A few hours of labor may save $$$ down the road. The crank and rods are a must have if converting a 352/360 to a 390.
Old Jun 9, 2007 | 07:16 PM
51dueller's Avatar
51dueller
Well it's too late as I've already hauled it off, along with as Sund pickup header and a whole load of metal. The crank would have needed to have been turned another .020 under to be useable and it would have taken quite a bit of work to save the rods since the pistons are siezed and there was a cylinder ridge. I don't have any FE engines and don't plan on any in the future.
Old Jun 9, 2007 | 11:27 PM
66gpw's Avatar
66gpw
Ah man I would of took the 390 to hang onto here. I read this thread too late. Suxs.
iggybob44
23
Sep 18, 2012 06:37 PM
1_BAD_66
17
May 22, 2009 10:57 AM
averagef250
Dec 11, 2004 09:42 PM
granitehauler
Dec 29, 2003 12:40 AM
karlsd
Jun 17, 2002 06:58 PM
