302 no fire
Old Jun 8, 2007 | 08:42 PM
Dean88's Avatar
Dean88
Question 302 no fire
Well, my problems have gotten worse from my last post: https://www.ford-trucks.com/forums/6...-on-302-a.html Now, I have zero fire. I pulled a spark plug, and well, there was no spark. I put a different map sensor, coil, and distrubitor on it and it still won't fire. Any help is greatly appreciated.
Old Jun 8, 2007 | 09:19 PM
wanitlifted's Avatar
wanitlifted
Did you pull the plug or the plug wire? Try taking just the plug wire and holding it near
a area of the engine that is grounded, you should see a spark if you are close to ground. Might want to use rubber handled pliers to hold the wire or you might get a shock.
Old Jun 8, 2007 | 09:29 PM
lv2race's Avatar
lv2race
Have you checked your codes yet?
Old Jun 9, 2007 | 08:31 AM
Dean88's Avatar
Dean88
I pulled the wire once and grounded it, and it didn't spark. Just to double make sure that I had no fire, I put an old spark plug that I had lying around and grounded it on the block, and there was still no fire. So, any suggestions to why I have no fire?
Old Jun 12, 2007 | 02:45 AM
specialist484's Avatar
specialist484
check for power at the coil with a voltage meter. It should have the same voltage at the battery terminals. Could also be PIP, stator, or the TIF sensor on the distributor.
Hotairjunkie
Modular V10 (6.8l)
Jun 9, 2013 01:48 AM
bigwin56f100
Ohio Chapter
Oct 1, 2012 11:14 AM
JMC302
Jul 28, 2010 07:42 AM
iracekx
17
Aug 22, 2006 12:43 PM
REDJAR
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Dec 16, 2004 12:13 PM
