Washer Fluid Basin???
Old Jun 8, 2007 | 10:57 AM
ejolliffe's Avatar
ejolliffe
Question Washer Fluid Basin???
Shouldn't there be a basin for my washer fluid on my '78 Ford F150? I can't find it and am wondering if the guy who rebuilt it left it out??
Old Jun 8, 2007 | 12:01 PM
dustinova's Avatar
dustinova
They probably left it out. I took mine out since I never used the washers, and it was pretty beat up. They're normally located on the driver side inner fenderwell right above the steering box (on my 78 at least).
Old Jun 8, 2007 | 12:24 PM
Mil1ion's Avatar
Mil1ion
I'm almost certain you mean Washer fluid reservoir
You can see what it looks like and where is mounts here.
Old Jun 8, 2007 | 01:00 PM
ejolliffe's Avatar
ejolliffe
Thank you guys!
Old Jun 8, 2007 | 01:01 PM
beartracks's Avatar
beartracks
I got a new one recently from one of our sponsors but I don't recall which one.
Old Jun 8, 2007 | 01:02 PM
ejolliffe's Avatar
ejolliffe
Was it hard to install? Is there a hose to the wiper motor or sprayer motor to hook up?
Old Jun 8, 2007 | 01:09 PM
NOCO77's Avatar
NOCO77
Spray nozzles are up in the cowl vents and the pump is integral to the reservoir.
Old Jun 8, 2007 | 01:10 PM
ejolliffe's Avatar
ejolliffe
cool, thanks. Now I just need to find a reservoir.
Old Jun 8, 2007 | 01:27 PM
NOCO77's Avatar
NOCO77
There should be some in the boneyards - tell them you want the pump too. Check to see if your pump power plug is still resting in the fenderwell area somewhere, and if not, get the plug with some of the pigtail wire too. Also, make them check for leaks before you fork over the cash - got burned on my first one - didn't check, drove 38 miles home to find out it leaked. They traded it out, but wasted time and fuel. :/
Old Jun 8, 2007 | 01:32 PM
ejolliffe's Avatar
ejolliffe
I will do that, thanks for the help!
Old Jun 8, 2007 | 01:51 PM
ejolliffe's Avatar
ejolliffe
NOCO, I went and checked and I found a 'two-prong' looking plug. It is a small black one and comes out of the wiring that ends up at the head light. Is this the plug that is for the reservoir? Thanks.
Old Jun 8, 2007 | 01:59 PM
NOCO77's Avatar
NOCO77
Yea, its probably it - it may have an all-weather o-ring around it - I think mine did, oval shaped plug if I recall, I'd have to go look...
Old Jun 8, 2007 | 02:03 PM
ejolliffe's Avatar
ejolliffe
yeah, it was a different shape, with two side plastic clasps on it. Not a very heavy duty plug or wiring. The plug is about the size of Jolly Rancher or a little bigger.
Old Jun 8, 2007 | 03:18 PM
NOCO77's Avatar
NOCO77
Yeah, I think you've found it - doesn't need to be very big - low current draw on the little pump
Old Jun 10, 2007 | 02:05 PM
fatherdoug's Avatar
fatherdoug
Also, keep in mind that the pump will NOT come with the reservoir. It has to be purchased separately.
