Sponsored by: Real Truck
4R100 Trans
Old Jun 7, 2007 | 09:02 PM
Shomo's Avatar
Shomo
Smile 4R100 Trans
Hello, I have a 2003 F250 7.3 PSD w/ 4R100 trans. I drained the trans. oil pan , dropped the pan & changed the filter. I only got 7 qts of oil out (the book says it holds 17.7 qts), I know this didn't drain the T.C. or cooler but is 7 qts about right? Is there a more complete way for the DIY'er.
Thanks , Shomo
Old Jun 7, 2007 | 09:22 PM
redford's Avatar
redford
FTE Leadership Emeritus
Welcome to FTE!
Yes, there is an easier way. Read this.
https://www.ford-trucks.com/article/...nsmission.html
Old Jun 7, 2007 | 09:30 PM
ReAX's Avatar
ReAX
Sounds close I think I used 9 qts when I did my valve body.
Old Jun 15, 2007 | 08:59 PM
Shomo's Avatar
Shomo
Thanks for the info
Shomo
Old Jun 16, 2007 | 12:17 AM
mbwrench's Avatar
mbwrench
sounds about right, has anyone heard of retrofit the factory trans external filter for the newer 5 spd auto to the e4od/4r100 trans?
Old Jun 19, 2007 | 03:59 AM
missouguy's Avatar
missouguy
Originally Posted by redford
Welcome to FTE!
I used this method and it was a piece of cake. I ran 20 quarts through to be sure I got it all. Didn't change the filter, Ford never mentions changing it. I probably will next time though.
Frank
