Sponsored by: Innova
Rosen Video system
Old Jun 7, 2007 | 03:33 PM
jd111404's Avatar
jd111404
Rosen Video system
I purchased a preowned 2000 expedition with a Rosen video system in it. The guy told me that I bought it from that the monitor was working fine a trip they took a week prior but when we tried it there was no power to the monitor. I looked under the dash and there is a power module of some type that I checked and had power. I then looked under the back seat and the module seems to have power there as well. Could the monitor just have gone out? How can I check it to see? If so is there a way to get a replacement monitor. The company was no help with that.
Old Jun 7, 2007 | 08:45 PM
ReAX's Avatar
ReAX
On the Rosen I installed it was an all in one, the only external module was a FM modulator. As I remember it, I ran two or three wires forward under the pass side headliner trim. I believe they fused at the glovebox. It was most likely constant, remote and ground that I ran. So your going to need to find the inline fuses and check them before you assume anything is wrong with the monitor. Rosen was fairly highend stuff, it's probably just a hidden fuse.
Old Jun 8, 2007 | 09:35 AM
jd111404's Avatar
jd111404
Thanks, I will take a look at that. Yea I can see that it is all in one. I have no power to the monitor where the buttons are on the side. I can press the source button and power but I get nothing. I also tried replacing the battery in the remote just to make sure. I didnt look under the glovebox side only the drivers side. There was a box there with a fuse but it was good and had a powerlight.
Old Jun 9, 2007 | 08:34 PM
wiingnut's Avatar
wiingnut
Look for a pinched wire
