Computer Chips & Tuners
Micro Tuner trans controls
Old Jun 12, 2002 | 02:19 AM
FTE Ken's Avatar
FTE Ken
Old Aug 29, 2002 | 05:57 PM
gkateley's Avatar
gkateley
Ken, Will the micro tuner for the V/10 allow you to change the converter lockup speed?
Old Aug 31, 2002 | 11:04 AM
FTE Ken's Avatar
FTE Ken
No. Just the shift firmness and shift points.
Old Sep 9, 2002 | 09:45 PM
3992824's Avatar
3992824
[updated:LAST EDITED ON 09-Sep-02 AT 10:46 PM (EST)]Hey Ken,
Can you elaborate on 'shift points?' Will the MT allow programming of the rpm of 1-2, 2-3, and 3-4 shifts? Can the shift points be programmed without changing the shift firmness?
Also, how can you find out WHAT can be programmed with the code you've got?
Does the MT leave a trace when the computer is returned to stock?
Thanks
Old Sep 9, 2002 | 09:49 PM
FTE Ken's Avatar
FTE Ken
>Will the MC allow
You can change the shifts in a mph scale with individual control over each gear by up to approximately 10mph each.
>Can the
>firmness?
Yes.
>code you've got?
Only by plugging it in and using it. Basically, whatever Superchips can accomplish shift-wise with an ECU code in the chip they can also do with the tuner. No way for me to know all the characteristics of each code yet because there are sooooo many of them!
Old Sep 10, 2002 | 10:53 AM
crjackson's Avatar
crjackson
OK. And would anyone know why all the diffent codes when there are only a few different drivetrain configurations available?
Old Sep 10, 2002 | 11:41 AM
FTE Ken's Avatar
FTE Ken
Warranty issues, problem solving (such as engine ping in areas with bad gas), customers unhappy with driving characteristics, cold weather areas, high altitude, the list goes on......
Old Sep 12, 2002 | 01:08 AM
3992824's Avatar
3992824
Hey Ken,
How do the trans features of the Microtuner compare with the Dura Trans unit.
Specifically, raising the OD shift point?
Thanks again
D Buck
Old Sep 12, 2002 | 08:27 AM
FTE Ken's Avatar
FTE Ken
The Dura Trans is not a transmission controller, not exactly. Its an overdrive controller. It controllers the speed at which the overdrive kicks in and turns off. It doesn't let you set gear ratio, tire size, shift firmness, or shift points for all gears.
Old Sep 23, 2002 | 07:05 PM
batman's Avatar
batman
Can the Micro Tuner (gas) remove the speed limiter or increase the speed limit (how much?).
Does the Micro Tuner have different tuning modes (e.g., performance, towing, etc.?)
Thanks,
Gary
Old Sep 23, 2002 | 07:20 PM
FTE Ken's Avatar
FTE Ken
Yes. No specific limit, either removed or not removed.
No.
