Towing Problems
Old Jun 7, 2007 | 05:18 PM
blackhat620's Avatar
blackhat620
gf350,
The Visconic fan on the 6.0 is electrically controlled by the PCM based on several varibles input to the PCM by numerous sensors on the engine. It gets louder under greater load and cycles on and off as the PCM deems necessary. First time you hear it you will swear the engine is coming through the hood.
Old Jun 7, 2007 | 08:27 PM
Kep4's Avatar
Kep4
Jäger
Blackhat, I tried to rep you for your fine explanation and, more importantly, using the term 'Visconic', but I gotta spread some rep around first....
Old Jun 7, 2007 | 09:54 PM
mrxlh's Avatar
mrxlh
FWIW, I had the recall sticker put onthe degas bottle, however the tech did not lower the coolant level. I lowered it to 1/4" visable in the front nearest the cap, and have had no more puking issues since.
Old Jun 9, 2007 | 05:38 PM
msgtg's Avatar
msgtg
If you want it done right....just do it and avoid bitching about the crappy work someone else would have done.
DJ2
2009 - 2014 F150
19
Dec 13, 2015 11:19 PM
fyrmnk1
Jun 20, 2015 04:27 PM
1capitalkid
All Things Towing
31
Jun 7, 2015 08:56 PM
wickdgt
Modular V10 (6.8l)
29
May 3, 2015 07:01 AM
427 fordman
86
Sep 11, 2014 04:25 PM
