How does this look?
Old Jun 7, 2007 | 07:20 PM
alz's Avatar
alz
I've rented a small unit at a do-it-all rental shop. Was like $15 for the day. Just had to purchase the sand (medium) at Sears.
Old Jun 7, 2007 | 07:28 PM
DOHC330MustangGT's Avatar
DOHC330MustangGT
OK.... I'm not sure how good these pictures are, but here goes the first coat on my 306HO.
Old Jun 8, 2007 | 02:35 AM
DOHC330MustangGT
FWIW, I'm going to put about 2-3 more coats on.
Old Jun 8, 2007 | 02:40 AM
Skandocious's Avatar
Skandocious
Looks good already man. Good work.
-Chris
Old Jun 8, 2007 | 03:49 AM
hogdogs's Avatar
hogdogs
http://autobodystore.net/Merchant2/g...01/uni007a.jpg
This is what I use!!! One sweet little device! You could do the covers and pan in under 20 minutes...
Maybe 30...
Your stuff is looking good though!
Brent
Old Jun 8, 2007 | 04:46 AM
DOHC330MustangGT
Originally Posted by hogdogs
http://autobodystore.net/Merchant2/graphics/00000001/uni007a.jpg
Maybe 30...
Brent
I wish I had one of those when I did all this work! I spent all day yesterday sanding and grinding.
Old Jun 8, 2007 | 07:55 AM
hogdogs's Avatar
hogdogs
Well you know for future work. they only cost 35-50 bucks. Not that great for big jobs but sure is a handy little devil...
Brent
Old Jun 8, 2007 | 10:52 AM
DOHC330MustangGT
Brent
Do they come with the sand blast stuff for that price, or is that just the gun? The compressor is where the cost would get me since I don't have one.
Old Jun 8, 2007 | 12:20 PM
netscaner's Avatar
netscaner
If you mean the sand when you say sand blast stuff, you can get it at most lumber yard or construction supply places, probably even Home Depot.
I use play sand for the rougher stuff and the beading sand for a smoother finish, but it doesn't cut as fast.
Both are relatively cheap, and if you put some visquene down, you can catch, strain, and reuse it.
Old Jun 8, 2007 | 02:23 PM
hogdogs's Avatar
hogdogs
50 bucks buys the gun... Seems high but the convienience and small size is the cost I think. It will run off a pancake style small compressor. Then you have air for blowing off parts etc. I have used the $99 compressor to run an impact and die grinder but only for a few seconds at a time...
Brent
Old Jun 8, 2007 | 02:33 PM
Skandocious
Brent
Where did you buy the gun?
Old Jun 8, 2007 | 02:39 PM
hogdogs's Avatar
hogdogs
I got mine off the Cornwell tools truck. I did a search last night to get the jpg and there are many sources for it including e-bay... to buy local I would call around to the paint and body supply houses.
Brent
Old Jun 8, 2007 | 02:41 PM
  #28
hogdogs's Avatar
hogdogs
Are you leaving it silver or is that a base to a candy type final color? I always wanted a pretty motor that matched my paint but know it be pretty long as I don't own show trucks...
Brent
Old Jun 8, 2007 | 10:34 PM
  #29
DOHC330MustangGT
Brent
No base coat to a candy since this is a work/toy hualer and not a show stopper. I just wanted to clean it up while rebuilding and it look semi-cool under the hood. lol
That color is Cast Coat aluminum. I have 2 more coats to go and after it's run up to temp I hear it will darken a tad.
Old Jun 8, 2007 | 10:35 PM
  #30
Bruce R Leech's Avatar
Bruce R Leech
it looks real nice I like the color but a few tips I would not have painted the inside of the filler neck or any thing that is inside of the engine. the spark plug holes and gasket serfices are a real no no. did you get over spray in the cylinders?
screw in some old spark plugs and spread a little grease on the gasket serfices before you paint.
