Computer Chips & Tuners
Ken: v10 chip question?
Old Jul 15, 2002 | 02:23 PM
Hiexcur's Avatar
Hiexcur
Looking at a diablo deltal chip for my 2000 excursion V10. Mods include k/n fipk, throttle body spacer, bbk 65mm throttle body, flowmaster 40 duel out, 6" skyjacker lift, 37" goodyear gsa. Would you suggest the 2 program or the 3 program delta chip? Do the mods need the extra for the custom chip?
thanks
Russell
Old Jul 15, 2002 | 02:50 PM
Hiexcur's Avatar
Hiexcur
Ok duh, should of looked in the question section. I do have one question about the 87 oct performance side of the 2 program chip. What does it really do? (tranny, timing, fuel mixture?)
Does the custom chip do any changes for tire size?
Russell
Old Jul 16, 2002 | 01:50 PM
FTE Ken's Avatar
FTE Ken
The 87 oct program is pretty much going to do everything the high octane side does (shift points, line pressue, etc.) except the timing curves will not be as advanced nor will the fuel mixture be leaned (the advance is where most of the horsepower comes from). We can program the chip for most tire size changes.
Old Jul 16, 2002 | 02:43 PM
Hiexcur's Avatar
Hiexcur
So all I need to order is the 87/92 delta chip with a program mod for the larger tires?
Russell
Old Jul 17, 2002 | 10:49 PM
FTE Ken's Avatar
FTE Ken
Correct.
Old Jul 18, 2002 | 11:12 PM
Hiexcur's Avatar
Hiexcur
ken
thanks for the help. I have the chip on order. I'll get back to evryone on how she runs after the installation.
Russell
Old Aug 21, 2002 | 06:57 PM
crjackson's Avatar
crjackson
Ken,
I'm not too edumacated on the chip scene. My 2k Excursion V-10 has a few intake/output mods, but feels a bit slothful and downshifts quite a bit on freeway grades where my honda doesn't. Would a chip help, and if so, which one?
I tow 8k rarely. I go offroad with about 1600 lbs of gear often.
-CRJ
2000 Excursion LMT, 6.8 V10, K/N FIPK, throttle body spacer, FM70 2.5" dual out, 4" Procomp/skyjacker, 6x Rancho 9000's, 35" Procomp A/T,
Old Aug 22, 2002 | 04:57 PM
FTE Ken's Avatar
FTE Ken
Good question!
Yes, a chip will help with this. A common complaint about Fords is the transmission. Not only do they give you mushy shifts, they also treat overdrive like a regular gear. This causes the truck to go into overdrive too soon, result in too much upshifting and downshifting. Not only will the chip give more power to hold the gear the truck is in, it also adjusts the shift points up so there is less hunting for gears. You'll be especially pleased with the improved shift speed while towing and will notice it more then when unloaded.
Old Sep 18, 2002 | 08:54 AM
crjackson's Avatar
crjackson
All right Ken,
I received the SuperChips tuner and reprogrammed using the SC default program. So far I really like the lower end shifting control. On the freeway I haven't noticed much difference. I probably need to play with the shift points for 3rd and 4th gears.
One problem, though. My truck is apparently one of those that the SC tuner doesn't recognize, therefore can't adjust for gear/tire changes. At this point, would I be better off just getting a programmed chip for less cash? What got my wife excited about the tuner was the speedo correction, but now I have nothing to sell HER
Thanks,:-(
Old Sep 18, 2002 | 09:04 AM
FTE Ken's Avatar
FTE Ken
If the tuner can't change your tire/gear size for your code, then Superchips won't be able to do it with a chip (if they could, they'd do it with the tuner too since it uses the same code). If this is the case, a dealer can adjust it. Also, a Superchips chip with custom code will cost more than a tuner.
Old Sep 18, 2002 | 09:19 AM
crjackson's Avatar
crjackson
Thanks for replying Ken...
Do you mean a Ford dealer, or Superchips dealer?
>a tuner.
Does this mean I need a custom chip for my truck? Or are you thinking about the shift points I mentioned, or the tire/gear program?
Thanks,
Old Sep 18, 2002 | 10:19 AM
FTE Ken's Avatar
FTE Ken
Ford dealer.
>>a tuner.
No. Just letting you know that a custom Superchips module ain't cheap these days. They doubled their custom fees on February 14th, 2002 (and quadrupled them for Supercharger applications!).
Old Sep 18, 2002 | 10:57 AM
crjackson's Avatar
crjackson
Ken,
Do you think I might get the results I'm looking for (tire/gear changes) from the Diablo Delta?
-CRJ
Old Sep 18, 2002 | 11:09 AM
FTE Ken's Avatar
FTE Ken
No. If Superchips can't change the speedo odds high Diablo can't either and visa versa. You'll need a Ford dealer to do it. In some cases only the shift points can be changed to compensate and the speedo is corrected externally to the computer.
Old Sep 18, 2002 | 11:25 AM
crjackson's Avatar
crjackson
[updated:LAST EDITED ON 18-Sep-02 AT 12:25 PM (EST)]Bummer. At least I have shifts that make you say "Cool!" and a better sounding and quicker launch from start
Any chance these ECU codes will become available to Superchips in the future? Or am I stuck with this anomalous ECU?
-CRJ
