Computer Chips & Tuners
94 Explorer RPM Limiter
Old Oct 1, 2002 | 02:55 PM
Forester's Avatar
Forester
Can anyone tell me or tell me where to find what RPM the RPM limiter should engauge on my 94 Explorer 4x4 auto 4.0L motor? Stock everything.
Regards,
Forester
Old Oct 2, 2002 | 08:10 PM
FTE Ken's Avatar
FTE Ken
It depends on the ECU and code. Generally, the rev limiter isn't the concern, as you'll bump the speed limiter first (except for the neutral limiter).
Old Oct 3, 2002 | 05:58 AM
Forester's Avatar
Forester
The RPM limiter kicks in at 4200 RPM on a rig that is completly stock and only has 27000 miles on it. Makes it tough when you punch it on the freeway to get out of trouble and the transmission won't shift into high because the limiter is engauged. You must let off the gas to get it to shift. Thats why I would like to know where to start to correct this problem. Is the limiter too low or is the transmission shifting wrong.
Thanks for the reply,
Forester
Old Oct 5, 2002 | 02:53 PM
FTE Ken's Avatar
FTE Ken
Old Oct 5, 2002 | 02:54 PM
FTE Ken's Avatar
FTE Ken
A Superchips chip will raise that significantly, to about 5500 rpm.
Old Oct 6, 2002 | 01:10 AM
Forester's Avatar
Forester
>5500 rpm.
What if I have a bad rpm sending unit, where ever that may be, most likely on the ignition module, feeding the computer bad info. I presume that a superchip would suffer from the same bad info. Thats is why I need to know what the current computer's value is to enguage the rpm limiter.
Thanks for responding,
Regards,
Forester
Old Oct 10, 2002 | 04:04 PM
FTE Ken's Avatar
FTE Ken
If the unit was bad the vehicle would run like crap. It basically would go into open loop operation. The computer uses a combination of speed, RPM, gear and throttle position to pull timing data from a 3 dimensation table. If you had a repair or part defect problem without a chip it would be there with it as well.
akamacgyver
Jun 24, 2012 05:11 PM
Fleetsuper
May 6, 2009 01:34 PM
Fleetsuper
May 6, 2009 10:43 AM
HMFX4IC
2004 - 2008 F150
Feb 9, 2007 07:20 PM
Carlene
Florida Chapter
May 21, 2003 09:59 PM
