Parking/E brake D60 1975 Highboy
Can anyone explain or does anyone have a decent picture of the rear parking brake cables and where/how they go into the backing plate?
I put new rear cables on both sides (old ones were torn off by the PO) and the new ones
go into the backing plate at a 90 degree angle, but the parking brake arm in the hub is at an angle where it is causing the cable to bind up and it is hard to set and release the brake...
It almost seems like they should go into the backing plate at a slight angle - I'm thinking there may have been an adapter??
help?
help?
Originally Posted by ReAX
All of mine went in at an angle. Like you have noticed, if the cable tries to pull at right angles, it just binds up. My 9" was the only one I ever spent any timing looking at. The steel wrapped lines have a bracket/base that sets the angle.
I just went out and looked at mine, they do go in at a 45 degree angle.. I will have to look at it tommorow to see if I can tell if it is a bracket or what, the cable was straight in to something so you might be missing a part. hope that helps and I will look tommorow when there is some more light.. can't seem to find a flashlight right now...
Look here. http://www.autozone.com/az/cds/en_us...rInfoPages.htm
I got my parking brake cables from greensales. Number Dummy was good enough to dig up a part number for me, but mines a Supercab and the cables are NLA.
Thanks tractorman that's a nice diagram. I see the image #4 and the backing plate is angled where the cable goes into the drum. My 75 is flat on the backing plate...so the cable goes in straight. Don't know what the heck is up with that, but there must be some part I am missing or something - maybe I need the correct cable. Any other thoughts?
Edit: maybe I'll take a picture so you all can see what I have...
Ok, well I spoke to the parts dept at my dealership - the part # is D5TZ2A635C for both rear brake cables. Anybody know if there is a year specific cable for 1975? The parts guy seemed to implicate that there was. Oh, and it is a non-available part...so anybody know where/if I can get these parts?
Originally Posted by tractoman
Try Greensales. Mine were NLA too but they had them. You have the wrong cables. My backing plate is flat too. The cable has a plastic guide nipple to orient it properly in the backing plate.
I may have found the part I need:
http://www.partsamerica.com/ProductD...pe=686&PTSet=A
This is suggested to fit the F350, but I see the part at the end of the cable that looks like it will make the cable go in at an angle like I need. I will post the results after I get them!
Update:
Well, the parking brake cable has the correct angled end and fits perfectly...but the housing is just a few inches short, so it won't work. Anybody else have a source for a longer cable (besides greensales)?
D5TZ2A635C is the Ford part#...
and BTW the cables I purchased locally are priced @ $30.00 and I need both left and right. I would love to support GS, but I think the price is a little high.
Try Y2K Ford, http://www.trademotion.com/partlocat...?siteid=214072 a forum sponsor. They also, have NOS or can search for it from dealers around the country although the pricing may be close to what GS is asking if they can find it. Good luck.
Wagner
F108579 BRAKE CABLE 44.44
[Parking Brake Cable]
Right Rear ; Regular Cab 4x2 Fr Ser# Y60-001 ; AWD Fr Ser# Y40-001
F108580 BRAKE CABLE 44.44
Left Rear ; Regular Cab 4x2 Fr Ser# Y60-001 ; AWD Fr Ser# Y40-001
F108581 BRAKE CABLE 48.80
Left Rear ; Crew Cab 4x2 ; Regular Cab & AWD ; Before Ser# Y40-001
F108582 BRAKE CABLE 54.43
Rear Left ; Reg Cab, Fr Ser# Y40, 001 To # Y60, 001
F108583 BRAKE CABLE 54.43
Rear Right ; Reg Cab, Fr Ser# Y40, 001 To # Y60, 001
F108584 BRAKE CABLE 47.67
Rear Right ; Supercab
Rear Right ; AWD ; Supercab
F108585 BRAKE CABLE 47.67
Rear Left ; Supercab
Rear Left ; AWD ; Supercab
F108586 BRAKE CABLE 48.80
Right Rear ; Crew Cab 4x2 ; Regular Cab & AWD ; Before Ser# Y40-001
F108800 BRAKE CABLE 57.76
Front ; AWD ; Fr Ser# Y60, 001
F38603 BRAKE CABLE 41.90
Services Cables Up To 120 ; Fits Most Models
AWD ; Services Cables Up To 120 ; Fits Most Models
Delco
18P1583 18037817 \CABLE P 51.44
[Brake Cable]
Rear Left ; 4WD, Reg Cab, Built Before Y40, 001
[Brake Cable]
Rear Right ; 4WD, Reg Cab, Built Before Y40, 001
18P331 18033249 \CABLE- PAR 65.62
[Brake Cable]
Front ; 4WD, Crew Cab, From Serial# Y40.001 90 7/16 Front Cable
18P374 18033292 \CABLE- PAR 55.68
[Brake Cable]
Rear Right ; 4WD, Crew Cab, From Serial# Y40.001
18P375 18033293 \CABLE- PAR 41.42
[Brake Cable]
Rear Right ; 138 WB
[Brake Cable]
Rear Right ; 4WD, Reg Cab, From Serial# Y60, 001
18P376 18033294 \CABLE- PAR 35.10
[Brake Cable]
Rear Left ; 4WD, Reg Cab, From Serial# Y60, 001
[Brake Cable]
Rear Left ; 138 WB
18P377 18033295 \CABLE- PAR 59.22
[Brake Cable]
Rear Left ; 4WD, Crew Cab, From Serial# Y40.001
18P379 18033297 \CABLE- PAR 50.80
[Brake Cable]
Rear Left ; 4WD, Reg Cab, From Serial# Y41, 001 to Serial# Y60, 001
18P380 18033298 \CABLE- PAR 50.80
[Brake Cable]
Rear Right ; 4WD, Reg Cab, From Serial# Y41, 001 to Serial# Y60, 001
18P678 18033596 \CABLE- PAR 90.10
[Brake Cable]
Front ; 138 WB
18P85 18033003 \CABLE- PAR 53.90
[Brake Cable]
Front ; 4WD, Reg Cab, From Serial# Y41, 001 to Serial# Y60, 001
18P87 18033005 \CABLE- PAR 44.90
[Brake Cable]
Front ; 4WD, Reg Cab, From Serial# Y60, 001
[Brake Cable]
Front ; 4WD, Crew Cab, From Serial# Y40.001 108 1/2 Front Cable
Does this help at all?
Delco
[Brake Cable]
[Brake Cable]
[Brake Cable]
[Brake Cable]
[Brake Cable]
Rear Right ; 138 WB
[Brake Cable]
[Brake Cable]
[Brake Cable]
Rear Left ; 138 WB
[Brake Cable]
[Brake Cable]
[Brake Cable]
[Brake Cable]
Front ; 138 WB
[Brake Cable]
[Brake Cable]
[Brake Cable]
