thermostat housing
Old Jun 6, 2007 | 12:33 AM
mooncricket's Avatar
mooncricket
thermostat housing
does any one kno what the vacume lines going to the thermostat housing and do i need them
Old Jun 6, 2007 | 12:37 AM
Jermafenser's Avatar
Jermafenser
They are PVS (ported vacuum switch...) they open/close vacuum sources at a certain temperature for emissions.
As you needing them, that depends.
Old Jun 6, 2007 | 12:43 AM
mooncricket
ive already removed every thing emisions related th only thing im worried about is that my vacuum advance goes in to it but i can rout that else where right
Old Jun 6, 2007 | 01:09 AM
Torque1st's Avatar
Torque1st
Posting Legend
The PVS switch is used to direct full vacuum to your advance when the engine is cold to improve idle and efficiency. When the engine warms up it directs ported vacuum to the advance mechanism. In some systems when the engine gets very warm the PVS directs full vacuum to the advance so that the engine idle speed and air circulation is increased.
Old Jun 6, 2007 | 01:20 AM
mooncricket
so do i need to keep it
Old Jun 6, 2007 | 01:28 AM
Torque1st's Avatar
Torque1st
Posting Legend
Use it for it's intended purpose.
Remember that when you remove the EGR you will need to recalibrate your distributor. There is a ton of info on that subject already here.
