timing cover explosion
Old Jun 5, 2007 | 05:46 PM
90ford4x4's Avatar
90ford4x4
i was on the highway and i was mergeing on and all of a sudden poof, lots of smoke and started to over heat, so drove home .5miles. got there let it cool and put water in it, with the hose started spuing out, took water pump off and the timing cover i cracked, and the fan went bad so now i need to change tyhe timing cover. i might want to change cams while i do this.
Old Jun 6, 2007 | 01:36 AM
88F-150pimp's Avatar
88F-150pimp
do you have a question?
Old Jun 6, 2007 | 08:35 AM
lostin90s's Avatar
lostin90s
It would be a good time for swap . I'd check compression first . Usually its # 8 failer for me or the bottom end letting loose so I don't worry about cam much . But would be a great time to put in the heavier cam and rollers..
Good luck LOST
Old Jun 6, 2007 | 11:56 AM
Kemicalburns's Avatar
Kemicalburns
compcam 35-255-5, replace the timing chain as well while you are there.
