Code 552 - Air Management
Old Jun 5, 2007 | 03:58 PM
alstieg's Avatar
alstieg
I got a 5.8 in a '95 ('96 motor) 4x4. i get the cel off and on. ran the codes and the main code was 552 Air management 1 circuit failure.
I figure I have a air leak so I did a visual check on all the small lines and didn't find anything. its almost impossible to find slits in the plastic hoses. truck idles ok but doesn't seem to get as good mpg.
are there little solenoids or switchs that could be bad?
Old Jun 27, 2007 | 09:57 AM
amish77's Avatar
amish77
Not sure, but the ether test is a good idea. If you spray a Small amount of ether around the vacuum hoses, the idle will tach up when you hit a line that is leaking. The vacuum sucks the ether into the intake, and the extra fuel overrides the engine management and revs the engine. Basically use small shots of the stuff for and wait a couple seconds between each shot. Starter fluid is what I use, but other ethers are available. I've heard of this being done with propane as well, but I'm not familiar with the exact method.
f100beatertruck
15
Dec 12, 2023 01:53 PM
GrumpyTroy
Nov 15, 2015 01:44 PM
mudbug3854
Nov 29, 2010 03:37 PM
suthrnslew
Mar 21, 2004 11:13 AM
Trigger1911
Jun 5, 2003 08:55 AM
