Rewiring 36 pickup
Old Jun 5, 2007 | 08:21 AM
36fordhotrodtruck's Avatar
36fordhotrodtruck
Rewiring 36 pickup
Any one know what the 3 16 gauge wires are on the ignition switch, it appears to be out of a torino about a 70-72?? they are'nt hooked to anything just hanging there. Also is no 12 wire heavy enough for the headlight wiring it is converted to sealed beams.
Thanks DD
Old Jun 5, 2007 | 09:53 AM
subford's Avatar
subford
Thanks DD
The three wires should be power, to Ignition Resistance Unit and gauges.
Here is a wiring diagram for a 1938.
http://i54.photobucket.com/albums/g91/subford/Flathead_Electrical_wiring1938.jpg
And the switch on a 1941.
Old Jun 5, 2007 | 01:24 PM
Franklin2's Avatar
Franklin2
12 gauge will be plenty for the headlights.
Old Jun 7, 2007 | 08:00 AM
36fordhotrodtruck
Thanks Bill and Dave but my question is on a 70-72 torino ignition switch column mounted, it has 4 primary wires batt. ign. start. aux. 10ga. wires then it has 3, 16 ga wires on the very end 1 is a ground. When the roddes my truck 20+ years ago they used a torino as a donor vehicle, eng, trans, stearing column and ign & turnsignal wiring, 9" rearend, seats. See my delimma??
Thanks DD
Old Jun 7, 2007 | 08:45 AM
subford's Avatar
subford
They are:
Proof #1, Red-white stripe goes to the Hot Warning Lamp.
Proof #2, Purple-white stripe goes to the Dual Brake Warning Switch.
Ground, Black.
P1 & P2 are connected to the ground wire when in the start position.
These wires are for checking the Lamps condition.
Do you need a diagram of the plug?
Old Jun 7, 2007 | 09:10 AM
36fordhotrodtruck
Thanks, no I have to cut the harness off and feed my fuse panel and start sol. and ign. I will not be using these wires I'll just have to cap them off to prevent shorts.
Thanks again DD
Old Jun 7, 2007 | 09:30 AM
subford's Avatar
subford
Thanks again DD
Here is a link to a diagram of the wiring that you may be using then.
http://i54.photobucket.com/albums/g91/subford/Electrical/Charging/Ignition71.gif
silvman36
15
Jan 16, 2014 02:10 PM
36th Tom
1947 and Older Ford Trucks
Jul 27, 2012 06:49 AM
X36
Sep 23, 2007 02:40 PM
aldauria
Nov 4, 2001 12:56 PM
truckzilla
Nov 3, 2001 09:35 PM
