adjusting the fpr?
Old Jun 5, 2007 | 12:50 AM
Strok'in's Avatar
Strok'in
Question adjusting the fpr?
how do i adjust the fpr? i pulled the 3/4 in. bolt on the right side of the fuel filter, pulled the spring out, put the bb in, put the spring back in the way it came out, lined the nipple on the bolt up in the middle of the spring and put the bolt in. is this correct? when i started it up and checked the pressure it showed 70 psi, how do i turn it up to 75? if what i explained is exactly how you shim the fpr, please let me know, i really dont want to mess something up by driving the truck to work tommorrow. how do i turn the pressure up?
Old Jun 5, 2007 | 03:28 AM
RubberDuck's Avatar
RubberDuck
You shimmed it correctly. The only way to make it adjustible is to use a small bolt and nut. I think it's like 10-32 or some small thread pitch like that. I don't think those are correct #'s but you get the idea. 70psi is pretty much perfect. I wouldn't mess with it. You won't see any gain.
Old Jun 5, 2007 | 02:12 PM
strokin'_tatsch's Avatar
strokin'_tatsch
dang... i'm 8psi low. oh well. yeah i would agree with cody on this, especially since he called mine good at 62psi. i would think you would see much of a gain at 75psi instead of 70psi, but who knows. good job cody.
