Need 460 swap info
Old Jun 4, 2007 | 09:21 PM
Dads79's Avatar
Dads79
Need 460 swap info
I going to try and swap in 460 into my son's 79 Bronco. He was going to do it this summer but his stay in Iraq got extended. I want him to come home at Christmas and just be able to burn the tires off. We have a 78 F-150 2wd that the engine is coming out of. It's all complete. Already rebuild .40 over ,Edelbrock intake,carb,headers. I know I will need new mounts is L&L the best place to get them ? The Bronco has a 4" lift will I need to change oil pans ? I'm going to swap core supports to put the bigger radiator in the Bronco.Does the trans (C-6) just simply bolt up or is there something I need to know about that ? I know the starter and dizzy are the same. I guess my biggest concern is mounting the engine the proper way . Thanks for your help.
Old Jun 4, 2007 | 09:54 PM
mudder460's Avatar
mudder460
This question belongs in the swaps section but I can help you out.. Jeff's Bronco Grave Yard is a great place to get the motor mounts that you need. You will need to get a new oil pan also and the grave yard has that as well. I presume that the bronco has a 351M in it already, so yes the tranny will bolt right up. Good luck and I hope your son has a safe return. I just returned from Iraq myself, I know how he feels!! I know he will be happy to come home to his truck!
Old Jun 4, 2007 | 10:35 PM
Mil1ion's Avatar
Mil1ion
You're going to need a rear sump oil pan and oil pickup.
Special engine mounts.
at least with the 78 C6/351M you have a direct match up except for Flexplate.
That will have to match a 460
Northern Caveman
1978 - 1996 Big Bronco
Apr 19, 2012 06:11 PM
crazy-redneck79
Engine Swaps
Sep 11, 2010 10:35 PM
Charlie01
Aug 23, 2009 09:09 AM
6312galaxie
1961 - 1963 F100 Unibody
13
Jun 5, 2009 03:57 PM
mstoned1
Offroad & 4x4
Dec 12, 2004 11:38 PM
