Sponsored by: Real Truck
vacuum pump
Old Jun 4, 2007 | 07:53 PM
EaTmYtAiLpIpEs's Avatar
EaTmYtAiLpIpEs
vacuum pump
where is the location of the vacuum pump n a 2003 ford f-250 with a 5.4 v8 in it? THANKS!
Old Jun 4, 2007 | 08:12 PM
Beerstalker's Avatar
Beerstalker
Eatmy, I thought in your other thread we had narrowed your problem down to the shift motor? I thought you weren't getting power to the motor when someone switches it into and out of 4x4?
If you think it is just a vacuum problem you should be able to manually put the hubs in lock mode by truning the hub selector and then you will have 4 wheel drive. If that is the problem then your issue is the hubs and or vacuum pump.
Old Jun 4, 2007 | 08:34 PM
carls 250's Avatar
carls 250
There isn't a vac. pump on a 5.4 only a resevore.
Old Jun 4, 2007 | 09:53 PM
redford's Avatar
redford
FTE Leadership Emeritus
Well, that sucks..........get it?
Vacuum.....suck.....
OK, these aren't funny if I have to explain them.
Old Jun 4, 2007 | 11:24 PM
blackhat620's Avatar
blackhat620
No vacuum pump on gas engines only on diesel engines.
Old Jun 5, 2007 | 08:51 AM
Beerstalker
He's having problems with the 4x4 system, I might have told him vacuum pump but it's actually the vacuum solenoid isn't it.
Old Jun 5, 2007 | 05:32 PM
blackhat620
Beerstalker,
You are correct the ESOF system has a vacuum solenoid in it.
