Squeaky steering
Old Jun 4, 2007 | 07:35 PM
mancamp74's Avatar
mancamp74
Squeaky steering
just started hearing a squeaking sound when I turn either direction. Sounds like something is rubbing against the tires. Could it be my suspension? Is it still safe to drive until getting it looked at by a mechanic?
Old Jun 4, 2007 | 08:09 PM
rboeding's Avatar
rboeding
King pins? Bad ps pump or belt? Bad coupler joint between shaft and gear box? Just needs grease? I would bet on the King Pins. Try describing the problem a little more.
