8" disassembly
Old Jun 4, 2007 | 12:23 PM
Lee250's Avatar
Lee250
8" disassembly
I have an 8" rearend off of a 72 mustang and I got the pinion gear off but I can't get the diffrential out cause I can't figure out how to get the axleshafts out. Anyone know how to do this?
Old Jun 4, 2007 | 03:19 PM
85e150's Avatar
85e150
8" with a drop out carrier, right? Not an integrated diff with a back cover, correct?
If so, you pull the wheels and you will see the backing plates and axle bearings are held on to the ends of the axle by 4 bolts. Pull those, then fashion a slide-hammer if you don't have a real slide hammer, and hook it on the axle shafts and you should have the axle out in a few pops. You don't have to take the brakes apart to do this. Just use a wire to hang them up out of the way.
Now if you loosened the carrier from the housing, you need to run a few nuts up tight to hold it in place so the axle shafts aren't in a bind.
It goes without saying that the vehicle needs to be up on blocks secure enough to withstand a 7.5 earthquake. No K-mart jackstands, OK?
Old Jun 4, 2007 | 03:30 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The rear end from a 1972 Mustang will be either an 8 or a 9 inch. The WER 8.7 rear axles introduced in 1967, weren't used in Mustangs.
The only Mustangs that used an integral rear end (Ford WCY = 7 1/4" RG) were the 1965/70 6 cylinders.
Old Jun 6, 2007 | 01:12 PM
Lee250's Avatar
Lee250
All I know is that it is not a 9" and the diff comes out the front with the housing.
Old Jun 6, 2007 | 01:14 PM
NumberDummy
Then it's gotta be an 8 inch, because there's only two rear ends available in 1972 = 8 & 9 inchers.
Old Jun 6, 2007 | 01:15 PM
Lee250's Avatar
Lee250
and it is not on the car
