Howdy folks,
I have a 1996 4.9L straight 6, and I just replaced the PCM yesterday. I did this because I was getting three O2 sensor heater malfunction codes. I thought it was odd that 3 would go bad at once, so I went through the diagnostic procedure in the Ford service manual. The heater circuits checked out fine, so I got to the step "replace PCM". After some reading here on the forums and the results of the test, I was pretty confident it was the PCM after all and not something else. The O2 heater malfunction went away with the new PCM, however, after replacing the PCM, the check engine light came on AGAIN after driving some. This time it gave me code P0443 - EVAP purge valve malfunction.
I ran through the diagnostics in the Service manual again, and the purge valve seemed to check out fine, and the manual brought me to the "replace PCM" conclusion again.
Could the new PCM possibly be bad also? Or could there be something in my truck causing the computer to go bad? I find this strange.... Is there some other circuits I should check?
Any ideas? Thanks!
The Ford service manuals want you to replace the PCM a lot. In reality, the PCM rarely goes bad, so the original you replaced was probably fine to begin with.
I wish I could weigh in more on the code you're getting, but I haven't had to deal with that one myself.
check fuse#5 in the Power Distribution Box under the hood. It's for the 02 sensor heaters. Actually replace it. Remember a fuse that looks good isn't always good
after my 96 went in the shop to get the pcm replaced we got it home and found that chafed wires by the clutch spring under the dash which is why it kept poping the fuse and shorted out the o2 sensor circut hah funny huh?
Scndsin
I have a little over 63K on it. Not bad for a '96 huh? I use it daily to run around, not much heavy duty hauling.
As far as the O2 heaters, I don't have that problem since I changed the PCM. I just have the P0443 code now... I didn't have that one before... The connections from the PCM connector to Purge valve checked out fine. I'm getting the correct voltage also.
I guess I'll have to dig deeper into the wiring.... Maybe there is a bad connection unrelated to the Purge value and it is causing a bogus reading? :\
I wouldn't be in a big hurry to get this fixed, but I'm moving and I will have to pass an emmissions test. I'm not sure if they will reject me for this... Anyone know how strict Arizona is?
So there is a sensor on purge valve or it's electric? It's probably bad. It was posted here sometime before that something in the neighborhood of 90% of all pcms that are sent in to be refurbished are fine, nothing wrong with them at all. It's more likely in the grounds.
No sensor, it must be detecting an open circuit at Pin #56 of the PCM, a LG/BK wire circuit #191.
I checked the connection at pin 56, and the resistance was in the specs (between 30 and 38 ohms). I measured 34.4 ohms. I will continue checking things out tomorrow or maybe Wed....
Well, I found that some of the rubber connections on the vacuum tube were cracked and leaking. I replaced them, so I am hoping that maybe this was causing the valve to malfunction and throw the diagnostic code. Let's hope
