Alternator question
Old Jun 3, 2007 | 09:25 AM
Totally Tuna's Avatar
Totally Tuna
Alternator question
My amps light is on and my voltage is showing less than 12 volts. My mechanic tested the alternator and said it was bad. However, I found a small black wire with a 90 degree connection boot attached to it. I looked all around and could not find anything obvious that it should connect to. The only thing that I found that is remotely possible is a small bolt coming off the side of the altenator. It is about 3/4" long and smaller than a 1/4 / 20 bolt. Any info would be nice.
Also, if I take the alternator in to be tested would the test tell me what parts need to be changed out on it. I was told rebuilding one was not that big a deal.
My truck is a '92 F-250 7.3L diesel 4X4.
Old Jun 3, 2007 | 01:10 PM
Franklin2's Avatar
Franklin2
If you take it into the store, it will pass/fail. I seem to remember it listing the different tests that it fails or passes, but I don't know if you will be able to make heads or tails of what it's trying to tell you.
If it does fail, I think I would take it apart and look at it, but it would be nice to find some info on how to test some of the internals. I did a quick look and did not find anything, but you may be able to do some web searching and find out what's going on. I did look up some of the internal parts prices, and they are not cheap. The rectfier assembly is almost half the cost of a rebuilt unit. And the regulator assembly is not cheap either, so it's not like you can go in and replace everything and be cheaper than a rebuilt unit.
