1966 - 1977 Early Broncos
power steering for 68 bronco
Old Jul 31, 2000 | 04:57 PM
dadurham's Avatar
dadurham
IS THERE A POWER STEERING UNIT THAT WILL FIT MY 68 4X4 BRONCO -- IF YOU HAVE ANY INFO I WOULD APPRECIATE IT ----DAD
Old Aug 2, 2000 | 09:51 PM
pracklam's Avatar
pracklam
There are several companies that offer power steering kits. Check www.wildhorses4x4.com. They have two kits. One is about $650 and requires several modifications including a 2" lift. They also sell a bolt-on kit for about $1200 which comes with everything you need. This package consists of rebuilt stock units.
Good Luck
Old Aug 4, 2000 | 07:56 AM
dadurham's Avatar
dadurham
THANKS FOR THE INFO.
Old Aug 10, 2000 | 07:16 AM
DeenHylton's Avatar
DeenHylton
>68 4X4 BRONCO -- IF
>YOU HAVE ANY INFO I
I had a 1969 Bronco that I modified many years ago. I used a eary Ford Thunderbird power steering box that is powered thru the box and not with a "slave cylinder". You will have to fabricate a mount out of steel to fit the pump to your current frame rail. I believe the year of Thunderbird steering boxes were late 1960 models. P.S. you also have to change out the Thunderbird steering arm for the Bronco steering arm. If you can fabricate the mount yourself the whole swap shouldn't cost you more than a couple hundred bucks. Deen
Old Aug 22, 2000 | 09:45 PM
allie_d_9's Avatar
allie_d_9
HANDSOME
Nov 10, 2015 06:57 PM
Matt 68 F100
Oct 12, 2015 02:20 PM
highntight
Sep 10, 2013 09:18 AM
Bucket head
May 4, 2005 05:59 AM
mopower
Dec 13, 2004 12:28 AM
