Sponsored by: Real Truck
RAM Air?
Old Jun 2, 2007 | 05:15 PM
dfuser's Avatar
dfuser
RAM Air?
I know of the Zoo-Dad, but today while doing the front 05 conversion I decided to drill hole on this side of the grille. The usual place where everyone drills has a cover to force the air into the condensor. And since the Excusrion has 2 A/C's I wanted to insure all the air continues to route directly there.
http://dfuser.com/img/ram_air.JPG
I drilled 4 1.5" holes. I may connect each 2 together later on.
Thes holes get fed through the driver side openning in the grille.
http://dfuser.com/img/after.JPG
Bill
__________________
http://www.dfuser.com
(512) 750-7102
Old Jun 3, 2007 | 12:44 PM
ReAX's Avatar
ReAX
I did a similar project once for a Western Diesel kit on a customers truck. I think I removed alot more of the bulk head than that, so you should be good to keep cutting.
An intresting trick I use alot on plastic, that makes that and bedliner modification easy, is to put a roto-zip bit in a drimel with a flex shaft. It makes a mess, but it cuts through the plastic with ease and is very controllable.
Old Jun 3, 2007 | 12:47 PM
dfuser's Avatar
dfuser
I totally forgot about my dremel tool. I can use the rotozip blade to connect them together to one big oppening.
Old Jun 3, 2007 | 12:56 PM
ReAX's Avatar
ReAX
Yep and it works like a charm.
