question; looking for information and background on a coversion that allows a hot rod to run on propane. Runs aluminum heads, lots of compression, now with a dominator and wants to use propane on the street. I had a fellow years back put three two barrels on a side oiler FE motor as there was a limited choice on air valves and he wanted more CFM than was available. This would be a single fuel application. Any info is appreciated. thanks, don dixon, Norcross, GA
try gotpropane.com they are set-ups for offroad 4+4's but should work or give ya some info ya want at least ! let me know what ya find out + i'll do the same cause i'm lookin into the same thing for my 78 bronco + 65 falcon
gotpropane.com is good for info and ideas, but if you want the same parts much cheaper go to www.propaneguy.com he has just about any propane part you can think of, and lots that you probably never thought of
if you just want general propane info go to http://fuelsforum.rasoenterprises.com/index.php
theyve got about the best info and tech guys for alternative fuels
thanks darrin, thats great! , i like cheap! , is there any way you can get the e-mail address for him? my computer wont let me in(default mailer not installed properly??)that would be great thanks , rick
