Pull the valve covers and have someone crank it. Watch the valve spings they should all go down and up. If one or more gets hung that is the problem. I would check both heads.
i took of the vavlve cover and found that the aft push rod for the #5 cylinder fellout.Its lying on the bottom and seems to be in one piece. Im getting my mechanical fingers to pull it out tomorrow.
What would cause it to "pop-Out"? u dont think its bent.
