Replacement coil wiring connector
Old May 31, 2007 | 10:44 PM
gixxer1000's Avatar
gixxer1000
Replacement coil wire connector NEEDED !
I am looking for a replacement coil wire connector. Its for the 2 wires that go to the coil on a 96-5.8l.
The original is all corroded and I have no spark.
Are they available at autozone/partsamerica ?
Old Jun 1, 2007 | 03:31 PM
Franklin2's Avatar
Franklin2
You might be able to get one from Ford. I am familiar with the horseshoe connector on the duraspark II, but I don't recall what the one looks like that you need. I am assuming you have the square coil.
Does the coil have two flat terminals close together? If so, and you can't find a connector, I would take regular slip on crimp connector and redo the connection. The only danger in this is getting the wires on the wrong terminals.
Old Jun 5, 2007 | 03:35 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
I think it is Motorcraft no. WPT-397.
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
