E4OD and FIPL settings
Old May 31, 2007 | 10:17 PM
KJLYPW's Avatar
KJLYPW
Well, information posted on various sites have called for FIPL voltage sensing to be at 1.05-1.1 at idle, and 3.8 -4.3 WOT. Mine was set at 1.08, but I wasn't all that happy with the shift schedule, it would kick up a gear sooner than I liked, and would kick into overdrive at about 40mph. This resulted in pretty low rpms, high egts, and doggy performance due to lugging.
When I had my TC changed out due to clutch slipping, the guy at the shop said that 1.2 v was a better setting for the FIPL. I check some old posts here, an low and behold PLC7.3 had referance a TSB that called up 1.2 v at idle.
So not being a coward, I cranked my adjustement up to 1.2, and guess what, much happer with the sifts, doesn't kick into overdrive until 50 mph, and maintains better rpm/power ratio through the range. Hope others frustrated with E4OD performance will find this helpful.
Old May 31, 2007 | 10:44 PM
whatsparkplug's Avatar
whatsparkplug
My shifts are just too hard and holds gears too long at 1.2 volts. I've got mine set at 1.05 now and it's tolerable. I plan on doing a fluid and filter change soon and will play with it a little more.
FORDF250HDXLT
117
Feb 10, 2025 11:29 PM
kevind95
General Diesel Discussion
Jan 1, 2009 09:30 PM
j tate
Jun 6, 2008 09:20 PM
dakotajeep
16
Jan 26, 2008 10:45 AM
RxF
40
Apr 12, 2004 08:06 PM
