High Pressure Oil Problem- Again....
Here's what's got me stumped- 1997 F350 PSD manual trans, stock except exhaust and EBPV delete, 120K. A week ago it stalled in traffic. Got it restarted after sitting awhile but very weak- low boost, high EGTs. Tried to limp it home and stalled again once it got up to temp. Kicked CEL. Would not restart so I towed home.
Truck would start when cold but begin to stumble and eventually die once it got up to temp. Tach showed movement cranking but put in new CPS anyway. Checked fuel pressure- 50 idle/65@2500. HPOP res is always 1/4" from top. Changed engine oil and filter. Oil level was not high or low before change. No go. Borrowed scanner and got ICP above/below normal code (P1281). Changed ICP sensor. Not it. Removed IPR (timmerman nut was tight). Orings looked fine but disassembled IPR and cleaned. IPR seemed to have accumulated some metallic material inside (very fine like you find on a drain plug). Checked wiring to IPR connector, no problems found. Reinstalled IPR w/new orings and ran great!! My theory is that valve was sticking and once oil got thin she couldn't keep up with demand....
Three days later same thing- CEL on, low power, but did not stall this time. Limped home, scanned codes, ICP pressure again (different code P1211 I think). Checked the usual, fuel, wiring, etc. Removed IPR, appeared generally clean but a trace amount of metallic residue again. Not like first time but definately a trace.
Sending out oil sample tomorrow, thinking I will chase down a complete IPR at IH dealer just to start fresh but I'm thinking I may have a bigger problem here??? HPOP? Maybe the magnetic coil attracts metal dust over time but in 3 days? Hmmm...
Any ideas?
Thanks!
Matt "Lemangeau"
PS Forgot to mention, tapped gauge into RH head HPO bank- pump will produce 2500 psi when hot- but only during KOER self test of of scanner. Otherwise struggles to make 1500 when I stomp on it. 600 psi at idle until it starts to act up- then press drops off and stalls.
Sorry for the long post but I figured lets get what I know out in the open!!!
Skittlejr, good point on the oil filter- I did still have it and cut it apart this morning. No noticable debris- a very slight amount of metallic "paste" on the inside of canister (dirty side) but that is all....
Will update as soon as I find out more!
Lemangeleau
New IPR is installed- truck runs great. Everything checks out on the scanner so now I am just waiting for my oil sample results.
Will update when I learn more (or it stalls again....)
Lemangeleau
