emissions help needed!!!!
Old May 31, 2007 | 07:46 PM
vtjvt's Avatar
vtjvt
OK I just had my 84 f250 6.9 emissions tested and the dang thing failed!!
At 30% throttle it passed great with a 6.6% out of the 30% max,
AT wot it failed with a 33.6% out of the 30% max.
I am thinking an oil change and all filters any other ideas would be great.
Old May 31, 2007 | 08:51 PM
Winger235's Avatar
Winger235
I did not realize Utah was so strict. I live in NY (Western) and my lovely state (drips with sarcasm) adopted the California emissions crap. They beauty is anything older than 1995 is exempt and only costs me 10 bucks and out the door I go. Replacing emission control hardware is a truck payment by itself. Now your rig was over 8600 GVW in 1984 should have been exempt period. It definately is always a good thing to replace filters fresh oil etc. The only thing I can think of that would help emissions would be a fresh IP and injectors.
Old May 31, 2007 | 08:56 PM
vtjvt's Avatar
vtjvt
I just changed the air filter and on the short drive home it seamed like it was smoking quite a bit less, while changing the filter I remembered that the IP had been advanced, so after it cools down mabye I will put it back to where it was.
Old May 31, 2007 | 09:47 PM
PLC7.3's Avatar
PLC7.3
Using Biodiesel helps too if there is a station close......
Old May 31, 2007 | 10:55 PM
vtjvt's Avatar
vtjvt
A guy about 5 houses down brews it up in his garage, Mabye I will go turn in a few favors.
Old Jun 1, 2007 | 04:56 AM
mistakenID's Avatar
mistakenID
Sounds like it's over fueling at higher rpm. A clean air filter will help a lot IF the old one was getting loaded with dust/dirt. Has the pump been turned up??
The test is higher speed/rpm and lower speed/rpm. The high end is not wide open throttle nor do they do a snap throttle test......yet!! The guy testing can "make" it fail if he's using the wrong gear for the test and lugging the engine (manual trans) I don't remember what speeds are used, something like 40 mph and 25 mph.
Diesels are only im'd along the Wasatch Front. Salt Lake, Davis and Utah counties. Rest of the state is safety inspection only.
Old Jun 1, 2007 | 05:01 AM
ford390gashog's Avatar
ford390gashog
how about detuning the IP pump for the test? all you need to do is remove the cover on the pump and turn the allen head backwards a quarter turn.
Old Jun 1, 2007 | 11:05 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Utah must be getting a brown cloud just like Denver had years ago.
Old Jun 2, 2007 | 10:20 AM
mejonz's Avatar
mejonz
here in phoenix since my trucks over 8500 lbs I just did the opasity test and theres alot of brown cloud days here mostly dust
Old Jun 3, 2007 | 03:16 PM
vtjvt's Avatar
vtjvt
I am going back for a "retest" monday or tuesday, Truck is running alot cleaner so I should pass fine.
Old Jun 7, 2007 | 06:53 PM
vtjvt's Avatar
vtjvt
Well just a quick update, IT PASSED!!!! I am 100% convinced that the guy doing the test diddn't have a clue and was lugging the motor way to much, but even with his crappy driving the high end went from 33.6% to 29%
Old Jun 7, 2007 | 07:34 PM
ltfox's Avatar
ltfox
No emmison tests in my part of Utah!!! That sucks....
BAD RONALD
Mar 7, 2012 08:16 AM
DMH
Dec 16, 2010 07:32 PM
Animalistic
18
Dec 22, 2006 09:13 PM
JohnnyFromOhio
3.0L V6
Dec 29, 2005 12:06 PM
200000+F150
Mar 1, 2005 12:53 PM
