1978 - 1996 Big Bronco
89 AOD leaking
Old May 31, 2007 | 06:50 PM
jomo924's Avatar
jomo924
89 AOD leaking
i have an 89 full size bronco with a 30 over 302 from an old mustang,,, stock efi with a mass air flow and a mustang computer ,,, there seems to be a nice leak at the shift selector shaft , what is the proceedure to fix this??? also i need a new oil pan that will fit the (old mustang engine ) engines sump requirements (as it is now in a 4X4 and must clear the differential) AND it has to have the dipstick in the pan,,,,,,,any help would be greatly appreciated,,,,,,,oh i forgot to mention the trans is an 89 AOD
Old Jun 1, 2007 | 08:29 AM
Kemicalburns's Avatar
Kemicalburns
you should just run a 302 truck pan
as for the AOD leaking at the shifter , i imagine there is a way to tighten that up.
Old Jun 1, 2007 | 08:53 PM
jomo924's Avatar
jomo924
302 truck pans dont have the dipstick in them (well the ones i have seen anyway,,, there is nothing to "tighten up" to fix the trans leak, i need to know how to reseal the selector shaft
