Whistling, whining, rumbling, roaring, something to that effect. The important part is that the sound is eminating from the rear axle.
Why, what makes you think yours is going bad?
Good question I don't know?
I just still worry last time some shop told me my axle was worn and it was going to break and lock the rear wheels and have an accident, it's just going through my mind, but the other shop removed the cover and found nothing wrong just a normal wear, and they filled the axle with new oil, and that's it, other than that everything sound OK, BTW, these truck are very hard to hear for noises or sounds they are just noisy.
An axle replacement is quite expensive and lots of labor hours, so I'm sure the guy told you something was up.
If it's quiet and the wear pattern looks good, there's nothing to worry about it. You would hear the whine of it over anything else if it was going bad, trust me on that.
Thanks RP!
BTW, How good of a reputation have the Rangers rear differentials?
Do they last, even with some off road driving?
The 7.5" isn't exactly a strong rear end, but it'll happily tolerate day to day driving and minor off-roading.
The 8.8" is quite heavy duty for the Ranger...it's been used in F-150s and in many high torque and horsepower (500+) applications. It will tolerate a lot of abuse and has a wide selection of ratios, parts are cheap and easy to find, but rarely needed.
You mean the ratio#?
Mine is 3-73 I think?
Where did you get that #?
Nope, I mean the axle ring gear size. Two sizes are available in the Ranger, the 7.5" and the 8.8". In addition, the 8.8" comes with two spline counts, 28 and 31.
When you look at your axle tag:
What engine do you have? I seem to recall you having the 4.0L, which would give you the 8.8" for sure.
AN axle replacement is dirt cheap IMO. $125-200 per axle (guesstimate), take off wheels, and drums (or calipers and rotor) pop off cover, take out cross pin, and c-clips, remove axle reverse for install
My 7.5 with unknown miles holds up to my abuse. I dont think the oil had ever been changed in it. Dark black it was. Got a posi in there now. Does just fine with 5,500prm 1-2 hard shifts (with tire bark) and my 2-3 shifts.
Are you talking self replacement? I can easily see it being 125-200 an axle if you do the work yourself. Some of the shops around here want at least $300 PER SIDE to replace an axle.
i think i read somewhere that the 7.5 rear end is really close to = strength as the 28 spline ranger 8.8. the 31 spline 8.8 is the stronger of the rears. but as light as the ranger is, unless you put moster tires or a torqu. monster engine infront of it. both axles will hold up. the only axle i have had issue with is dana 28 ifs. i have blown out a few axle shafts on those. a friend of mine with a dana 35 blew out his front hubs but he had 38"s on his truck. so that to me was to be expected.
Edit* both the 7.5 rear and the 8.8 rear have the same downfall, they both use "C" clip retainers for the axle shafts. also remember the Fox body mustang? 79-93.. well from 79-87 used a 7.5 rear end, even on the GT with the 5.0 H.O. and if you drove them with some kind of sense they rears held up... till you hopped up the 302 and what not but even the 8.8 rears have a hard time keeping up with a well or over built (if there is such a thing lol) engine.
Reason: added info
yeah pilot Im talking about self replacement. If you're mechanically inclined at all it's easy
franken I would agree that from what i've read that from a strength aspect a 7.5 is almost as strong as the 8.8 because the 8.8 still uses 28 spline axles. I find no issues with using C-clips, but I guess that would depend on applications. I've got a friend from Indiana Running low 9 sec passes in his Impala that still uses C clips in his 8.5" 10 bolt
