Front end Help needed
Old May 31, 2007 | 03:29 PM
jmteam6's Avatar
jmteam6
I have a 1984 F-150 super cab that needs a rear axle. My buddy said if I pay the tow I can have his 1989 F250 regular cab his truck does not run and really is not worth fixing body panels rusted through and no interior. Any way I have measured the rear axle and know it will fit without and problems. My question is so I do not have to carry two spares will the front I-Beams and spindles fit my 150 as in a direct bolt on if so I'll do it. I'm not trying to haul more or anything just looking for a cheap way out. Thanks.
Old May 31, 2007 | 06:36 PM
Franklin2's Avatar
Franklin2
Maybe. If these trucks are 2wd, and both have coil spring front suspensions, it may swap. If they are 4wd, no. The 250 4wd has leaf springs suspension while the 150 has coils, and the frontends will not interchange.
Old Jun 1, 2007 | 08:27 AM
jmteam6's Avatar
jmteam6
both of them are 2wd with coils the i-beams look and measure the same just don't know about the bolts and radius arm. Thanks
