v code springs
Old May 31, 2007 | 12:20 AM
dannyo's Avatar
dannyo
v code springs
if i do the swap, do i have to do the rears as well? thanks a lot, guys.
Old May 31, 2007 | 01:00 AM
RACERX7775's Avatar
RACERX7775
i did the v codes in the front. check my gallery for some pics. looks level in the pics. rear suspension is completely stock. well, except the helwig sway bar and bilsteins. my x sits about 1 inch higher in the front. i/we need to get the f350 blocks and u-bolts to raise the back end up 2". that way, the rear will wind up 1" higher than the front so when heavy things are put in, it will be level.
