Restore stock stance
Old May 30, 2007 | 03:16 PM
ronpaternoster's Avatar
ronpaternoster
I swapped a 460 into a 2wd 77F150 Ranger and the front end is down at least 2 if not 3 inches from the extra weight of the 460. I want to restore it to original stance. I've identified the correct coils I need but I'm not sure what other parts will need replacement? I'm going to replace the radius arm bushings and the steering gear when I pull it apart..what else should be replaced at the same time?
Old May 30, 2007 | 10:31 PM
wizzard351's Avatar
wizzard351
the only other thing i would change is the bushing at the end of the i beams.but other than that the springs will be the only thing making your ride hight go up or down.all other stuff is the same
mmagang06
May 15, 2013 09:08 AM
gelato583
2004 - 2008 F150
Aug 13, 2011 03:22 PM
Cluney93
Jan 8, 2011 12:25 PM
thendrix
30
Nov 16, 2007 12:14 PM
