I just finished with my truck seats. I replaced the original bench seat with some Bronco seats and center console. Obviously they didn't match the interior so I was planning on reupholstering them and painting the center console. Finally, I got them reupholstered and chose a darker material to mimic the newer King Ranch style seats. I still have to recover the rear bench seat and maybe cover the arm rests on the doors and other places to finish the interior. I still have to replace the door panels with power stuff, but at least the front seats are done. Tell me what you think.
Looks great! How much changing did you have to do to get the Bronco seats to go into where the bench used to be? I was thinking about doing the same thing to my truck so I was just wondering if you had to do alot of work or if they just bolted in?
Thanks
Kenworthfan
The Bronco seat brackets fit the floor. The driver's side bolts in place on the outer two bolts. I had to drill holes and bolt through the floor for the inner two bolts. On the passenger side, only the outside front hole matches up and bolts in place. I had to drill and bolt through the floor for the remaining three mounting points. No big deal, with at least one factory hole lined, up, the brackets match up with the floor contours and makes drilling the new holes easy. The biggest hassle was getting past the exhaust shields underneath the passenger side seat. I didn't bother removing them, but it would have made it easier. All in all, it probably took a half hour to install the Bronco seats.
Really, I got my buckets from a 90' F-250, and when I tried to use some of the bench holes, it put the seat too far to one side. the steering wheel was directly over my right knee. Makes me wonder if they are different between a bronco and another truck. I just put them where I wanted them and drilled my holes.
The buckets I orignally got and installed in the truck were Bronco seats from a pre-87 fullsize Bronco. I reupholstered the diesel buckets from my 86 F250 which has the same buckets (thicker armrests) and the same rails as the Bronco ones. Five holes to drill and three bolt in place. The later models may have had different rails or mounting locations.
Thats true, the floors were contoured a little bit differently, which made the passenger side seat a bigger pain. I had to use a spacer on one mounting point, and the seat is a little crooked.
