Wet Spot in Cab
Old May 30, 2007 | 12:09 PM
txcoasting's Avatar
txcoasting
Question Wet Spot in Cab
I've got a 2004 f-150 Supercrew that has developed a wet spot in the center of the driver side floorboard. I haven't noticed any water coming from the top of the dash. Any idea what might be under there that could be leaking? Thanks in advance for any advice!
Old May 30, 2007 | 04:14 PM
kurtg3026's Avatar
kurtg3026
You did not get excited and pee yourself did you? That has happen to me, usually when I have had to many beers!
Old May 30, 2007 | 04:16 PM
txcoasting's Avatar
txcoasting
No such luck...
Old May 30, 2007 | 06:06 PM
WhëëlMå1's Avatar
WhëëlMå1
Is it just a circle of water? Can you tell if it is coming from any area (like if there was a wet trail from the transmission hump or something)?
Old May 30, 2007 | 08:23 PM
the4by4freek's Avatar
the4by4freek
Do you have the flow through center console with the shifter? If so, check your firewall just behind the brake pedal. There will be a circular cutout in the insulation material. Pull it back and see if the rubber plug is installed. I got lucky and caught mine before I drove through any big puddles. Dealer fixed it under warranty.
