What does this tube do?
Old Jul 19, 2007 | 08:51 PM
fastreddevil's Avatar
fastreddevil
on deleting the smog pump all you have to do is buy a shorter belt, and bypass it. plug off all vaccume lines to the intake manifold, go to the hardware store and buy 2 plugs to plug the back of the heads, and delete all the useless crap that was hooked up ( vaccume cans and lines, etc...) your truck will run better with all that gone.
Old Jul 19, 2007 | 11:06 PM
Blurry94's Avatar
Blurry94
I removed mine, ran a short belt and disabled the EGR and Thermactor switches with the tuning software I use (SCT Advantage). It's not going to gain you anymore power and not exactly a leagal practice, but it sure does clean up the engine bay.
Old Jan 31, 2008 | 03:45 PM
chissler's Avatar
chissler
does the 5.0 stang eliminate kit work on 5.8 f150's?
Old Feb 2, 2008 | 07:40 PM
Blurry94's Avatar
Blurry94
A 5.0 smog pump delete pulley works on a 5.8, if that is what you're asking.
Old Apr 13, 2008 | 01:03 AM
stangbanger's Avatar
stangbanger
Definately just run a shorter belt i have done the same thing numerous times on different motors its cheaper.
Old Apr 13, 2008 | 11:48 AM
flareside_thunder's Avatar
flareside_thunder
That's all fine and dandy except on my 95.....I can't run a shorter belt..I HAVE to have something in it's place.....
JR
whalebus2112
Aug 27, 2012 02:21 PM
RIKIL
Sep 11, 2011 11:05 AM
SmokeBlower
Exhaust Systems
27
Mar 5, 2010 09:09 AM
300/6 Freak
Jan 15, 2010 09:05 AM
SmokeBlower
18
Jun 24, 2008 11:59 PM
