post turbo temps
Old May 29, 2007 | 11:42 PM
Stroked Out!'s Avatar
Stroked Out!
post turbo temps
I had some gauges put in and they had put it post turbo what is the temp diffrence between pre/ post turbo?
Old May 30, 2007 | 12:08 AM
duffman77's Avatar
duffman77
Post Turbo will show cooler readings as the turbo is extracting additional energy out of the exhaust. Guys running EGRs will run hotter Exhaust than those not. There are threads out there than you can do a search on. Dont just trust the first answear that you get, other mods like higher flow exhaust systems also have an effect.
Old May 30, 2007 | 02:07 AM
blackhat620's Avatar
blackhat620
Difference between Pre-turbo(most accurate) and Post-turbo can vary between 200-800 degrees and it is not linear of consistant. Post-turbo temperatures are a guestimate of actual EGT temps at best.
