Desirable 351Ws
Old Jun 1, 2007 | 12:24 PM
rsalter66's Avatar
rsalter66
elect chokes can easily be fixed or converted to man, i just prefer 4bbls my self i'de stick with it if it was me
Old Jun 1, 2007 | 03:47 PM
dragogt's Avatar
dragogt
i want the 4bbl, just not sure if carb needs rebuild or not has'nt run/ben used in 3-4 years
Old Jun 1, 2007 | 04:23 PM
HemiEater's Avatar
HemiEater
i would get a kit and clean it.......it's nasty inside.....
I just did a 650 holley for a friend of mine that he pulled out of a ditch......it was real bad, not saying yours is like this one but the fuel leaves a nasty brown glaze like chit inside them and bugs will nest inside the air bleeds and vents........
I had to glass bead this one inside and out, you would not believe how bad it was. I hope it works when I'm done, had to paint it red..looks good.
Old Jun 1, 2007 | 05:05 PM
dragogt's Avatar
dragogt
yeah, i figured that I'd have to rebuild, just thats sumthing that I've never done before
how hard is it to do?
Old Jun 1, 2007 | 05:25 PM
HemiEater's Avatar
HemiEater
piece of cake..I'm doing a Holley 80555 spread bore for a chevy right now.......nice carb I would like to try one on my 302, looks like you could get better milage with one it has small primaries......
Old Jun 1, 2007 | 05:27 PM
HemiEater's Avatar
HemiEater
let me know if you need a hand. What kind is it. numbers?
Old Jun 1, 2007 | 06:15 PM
dragogt's Avatar
dragogt
dont know the #'s just yet, have to go pull carb to see
it's 150 mi from my house at dads place in country
tks for the offer, wll probaley need help when i get started on it
Old Jun 1, 2007 | 07:14 PM
baddad457's Avatar
baddad457
Originally Posted by Dirigo
Which ones had good heads? were any built with forged parts?
ALL Ford pushrod V8's had forged rods, NO exceptions there. Some are better than others, but they're all forgings. There's absolutely nothing wrong with the stock cast cranks. They've been used in every form of racing, including 500 mile Nascar races. We ain't talking chevy parts here. The 351C cranks were even run in Pro-Stock drag racing in the late 70's to mid 80's. The cast cranks are lighter than a forged steel one too. The only weak stock cranks I know of are the early 50/oz 5.0 and 255 cranks. There's also nothing wrong with running cast pistons either, as long as you're not super charging it or spraying it.
Old Jun 3, 2007 | 02:41 PM
Forever Fords's Avatar
Forever Fords
Internals are very strong on SBF, 69-70 351 windsor heads work well!
Old Jun 3, 2007 | 10:01 PM
mikeyswood's Avatar
mikeyswood
Stock head will flow just fine through 3000 RPM. If you are racing then the aftermarkent heads are the way to go. As for the orginal Q, the F4TE casting was my choice for the roller cam. I figured that those engine blocks would have seen a lot less friction in their time.
Mike
Old Jun 11, 2007 | 07:25 PM
JBradley500's Avatar
JBradley500
i thought that i would add on to this...i read today in an older mustang monthly mag that the 68 302 heads have the smallest combustion chambers and have 351w size valves. it was something i dont remember hearing before. maybe someone could find these heads instead of looking just for a 69 351w head.
Old Jun 11, 2007 | 07:35 PM
dragogt's Avatar
dragogt
may have been the boss heads?
Old Jun 11, 2007 | 08:07 PM
  #28
JBradley500
no it said 1968...i believe all 1968 (mustangs at least) had what i described in my above post.
Old Jun 11, 2007 | 08:40 PM
  #29
HemiEater's Avatar
HemiEater
smaller chambers but same size valves as any 302 head....
Old Jun 11, 2007 | 08:54 PM
  #30
JBradley500
Casting # C8OE-F
'68 302 4V heads
53.5cc Chambers
Windsor Size Intake Valves
