might be a dumb question...
Old May 30, 2007 | 08:28 AM
lrappl's Avatar
lrappl
Next time you press that button you should look carefully down the block. Someone's garage door is going to open!
Old May 30, 2007 | 08:56 AM
Xyzzy's Avatar
Xyzzy
In my house there's this light switch that doesn't do anything. Every so often I would flick it on and off just to check. Yesterday, I got a call from a woman in Madagascar. She said, "Cut it out." -- Steven Wright
Old May 30, 2007 | 12:10 PM
UKkid89's Avatar
UKkid89
Originally Posted by Corey872
I think the bubble with the red light is security. The headlight sensor is built into the rear view mirror. I don't know what the button does...I pushed it a couple times and nothing bad happened.
Quit, your making my garage door go up and down!!
Old May 30, 2007 | 12:46 PM
FORD7445's Avatar
FORD7445
the light is for your pats key.
Old May 30, 2007 | 04:21 PM
wildcard30's Avatar
wildcard30
It's the activation switch for the particle beam weapon installed behind the grill. It can vaporize a Dodge or a Chevy in less than a second!
Old May 30, 2007 | 08:42 PM
gui88ford's Avatar
gui88ford
ok, so i was messing with it today....i push the button and hold it down and the dash says zone 8....hmmmm, i'm still confused about what it does....
Old May 30, 2007 | 08:45 PM
WhëëlMå1's Avatar
WhëëlMå1
Do you see any black helicopters circling? It sounds like some sort of link up to NORAD.
Old May 30, 2007 | 08:47 PM
echavez1981's Avatar
echavez1981
Another dumb question my V6 is a 4.2l engine right??
Old May 30, 2007 | 08:49 PM
WhëëlMå1's Avatar
WhëëlMå1
Yes, it is.
Old May 30, 2007 | 10:15 PM
Horseapple's Avatar
Horseapple
what ever it is,all hells breakin loose in zone 8!
Old May 30, 2007 | 11:21 PM
VFR_Man's Avatar
VFR_Man
The real answer, drumroll please....., is that the button is used for adjusting/calibrating the compass.
If you hold it long enough, it will reset and you will have to drive in a bunch of circles ("no more than 5 times at no more than 3 mph") in a metal free area to recalibrate it.
Zone 8 is not correct for PA, by the way, Zone 10 for the west half and Zone 11 for the east half, approximately.
Old May 31, 2007 | 01:39 PM
genocidejunkie's Avatar
genocidejunkie
the button is used when calibrating the compass.
Old May 31, 2007 | 05:36 PM
  #28
gui88ford's Avatar
gui88ford
hmmmm....so, i'll go play with it and get to zone 11...
Old May 31, 2007 | 05:37 PM
  #29
last5oh_302's Avatar
last5oh_302
I still can't get past zone 1.
Old May 31, 2007 | 06:26 PM
  #30
wildcard30's Avatar
wildcard30
It's all good...
As long as you're in the zone. No matter which one it is!
