Sponsored by: Real Truck
Add-a-leaf
Old May 29, 2007 | 06:29 PM
mstiles19's Avatar
mstiles19
Exclamation Add-a-leaf
I just pickedup a set of front 3 inch add a leafs and one inch blocks or the rear for my O1 SD. Oce i put these on is there anything else i need to do to the truck like new shocks or any relocation brackets? I am also thinking about putting in a steering stabilizer? are they worth it? I use my truck mostly for hauling horse and boat trailers and i also spend lots of time with it in the mud.
Old May 29, 2007 | 08:14 PM
lowet's Avatar
lowet
If you get a true 3" of lift you may want a adj. track bar.
Old May 31, 2007 | 05:11 PM
ReAX's Avatar
ReAX
Shocks are generally only good for 2" of play. I'd suggest getting some shocks for a 4" lift. If your track bar fits, you might be alright. Sway bars are a give and take item. They will limit articulation of the suspension, but will reduce the movement of the body from the tires. Do front and rear bars together though, it can adversly affect steering if you only halfarse it.
Old May 31, 2007 | 09:44 PM
lowet's Avatar
lowet
I have rancho springs on the front of mine, they lifted it 3inches I put skyjacker nitro shocks on and a adj. track bar. my truck had front and rear swaybars.
