New member saying hello
Welcome! Nice starting point you have there. AFA magnets for bondo detection, one of the flexible sheet magnets works great. Our phone book comes with a calendar advertising one on the cover or look for one of the magnetic business cards or advertising that are popular with realtors and pizza shops, last resort would be a flexible refrigerator magnet from your local novelty store. They are less "sticky" than a solid metal magnet and will simply slip or refuse to stick over even a thin layer of filler. Slide it around and where it sticks will give an indication of the repaired area's boundaries. Some might be due to collision damage on the fronts and sides of the fenders for example. Our panel doesn't have a spot of rust on it, but the magnet told me where collision damage was filled over. I was actually glad a PO hadn't done more than fill in the dents, saved me a lot of work not only repairing the areas but in not having to fix someone else's messed up work.
Originally Posted by Randy Jack
Chris - Sounds like you may want to shorten the frame to set that bed on there right. It's not too tough a job, actually. By the sound of your past projects, I'll bet it is well within your skills also.
Originally Posted by true
The frame has already been chopped in the rear to compensate for the bed. However, they did it in a rather quick and dirty way. They simply cut the excess frame rails off of the rear instead of shortening it in two places. So my current situation is I have a 3 1/2" - 4" gap between the bed and cab, and the bed is so far forward that the rear end of the bed is nearly touching (about a 1/4" gap) the rear wheel fenders. Basically, the bed needs to be longer, or the frame needs to be trimmed down 3-4" in front of the bed. This will bring up other issues as well, so I am curious on some ideas people have on how to fix the situation. Extend the bed maybe?
Sounds like some frame sectioning and lengthening may be in order. I can give you some measurements as my bed is off the frame.
Best solution is to cut a 4" section out of the frame behind the cab to reduce it to a 110" wheel base, the size of the standard shortbed frame. If you have never shortened a frame before but have the welding skills to do a structural mod just ask for the best methods otherwise it would be safer to take it to a welder or have one come to you. You are fortunate to live in the heart of hot rod country so it shouldn't be too difficult or expensive to have anything you need done.
Great a local O.C. person. If your looking for some good parts check out John's F-Fun Hundreds in Anaheim. It's about a mile away from Disneyland. I drive by there everyday on my way home from work.
In fact I'm stopping by there in about an hour to get some parts suggested by some great guys here already. So keep those questions coming. Eventually, you'll get the right one.
Jeannine
Jeannine
Chris
#28
Jeannine
Jeannine
#29
Jeannine, are you going to the El Toro Fuddruckers car night tonight?
But if you can PM any info on the next meet or any other local meets I'd be intrested. My '53 Desoto needs to stretch her legs too.
