Getting gauges installed....
Old May 29, 2007 | 09:34 AM
Superdudey's Avatar
Superdudey
And it was suggested that i look into the quadzilla commander http://www.xtremediesel.com/index.as...OD&ProdID=1101
anyone use this? Is it better or as good as actual gauges? im looking to get a boost, trans temp, and pyro installed and was told that this would do well for what i want? Any opinions?
Old May 29, 2007 | 11:22 AM
blackhat620's Avatar
blackhat620
Superdudey,
These work just fine. If you like digital gauges go for it. I prefer traditional gauges with neadle pointers myself. The only difference with the digital gauges and standard gauges is that the digital gauges get there boost reading from the MAP sensor feed wire and are not quite as accurate as the mechanical gauge that taps into the CAC elbow.
Hope this helps
Old May 29, 2007 | 11:55 AM
Superdudey's Avatar
Superdudey
sure does! Thanks.
