Poor starting
Old May 29, 2007 | 07:59 AM
gumby's Avatar
gumby
Poor starting
Have an 85 F150 with fuel injection; it starts beautifully first time; after running and shutting off, I have to pump pedal and turn ignition 8-10 times to get it to crank again. Had new ignition coil and module installed at dealer. Any suggestions?
thanks much.
Old May 29, 2007 | 10:40 AM
Franklin2's Avatar
Franklin2
I would get a fuel pressure guage and measure the fuel pressure when you turn the engine off. See if you have fuel pressure when it wants to throw a fit and not start.
Old May 29, 2007 | 10:45 AM
gumby's Avatar
gumby
thanks
Dave,
I'll try that. I'm assuming a goober like me can figure out how to use a fuel pressure gauge once I buy one!
take care.
Mike
Old May 29, 2007 | 05:40 PM
CaptGuz's Avatar
CaptGuz
its not too hard... the last one i saw had directions on it. your engine carb'd or EFI?
Old May 29, 2007 | 08:33 PM
gumby's Avatar
gumby
thanks
thanks much. first year of EFI
Old May 29, 2007 | 09:26 PM
CaptGuz's Avatar
CaptGuz
yea try out the pressure gauge and let us know!
Old Jun 1, 2007 | 05:45 PM
rbaker6336's Avatar
rbaker6336
forget the pumping it don't do anything and try turning ignition on and off a couple times
